My power steering fluid is low, what kind should I use?
MReedBMWM3 Member Jun 15, 2006 #1 Messages 274 Likes 0 Location Tulsa Ok Jun 15, 2006 #1 My power steering fluid is low, what kind should I use?
andreyiv 2 Jun 15, 2006 #2 Messages 1,247 Likes 0 Location NY Jun 15, 2006 #2 I bet that it is Dextron III ATF (Automatic transmission fluid) but you should look on the cap, it tells you what to use.
E epj3 Senior Member Jun 15, 2006 #3 Messages 7,370 Likes 0 Location Lancaster, PA Jun 15, 2006 #3 Yup it's Dexron III ATF fluid... If you're anal, use redline or amsoil. If you're smart, at least use Castrol ATF. If you're cheap use walmart brand.
