I have noticed that the Coolant Warning light on the dash comes on every now and then when the heater is on. THen goes off a couple of seconds after the heater is turned off.
Coolant level is fine. This happen to anyone else?
It may just be a dirty, sludged-up sensor. Not sure why the heater on/off would have an effect. But the sensor, located in the bottom of the coolant fill tank, is a known failure item on older E36s.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
