- Deep socket set 8mm - 17mm. 17mm is used all over the suspension. You don't need anything bigger for regular maintenance. This will cover you for the spark plugs.
- Shallow 12 point 3/8" drive set is also good for tight areas around the engine.
- 8mm - 17mm combination wrench set, 6 point.
- Optionally, 8mm - 17mm combo set, 12 pt. There are a few tight areas where the 6 point won't work too well.
- Low profile floor jack
- I used a 2' piece of pipe on a ratchet and blew out the ratchet. Got a good breaker bar, now I put a 2' piece of pipe on it.
