Dear Friends,
i have got a 1995 318 is, The car have a problem that it doesn't start when i try to put the car on, what the car does is that it opens and right away shuts, i mean every thing sounds good, no noise nothing, it just starts as if it's going to work and then the rpm goes down to zero and shuts,
and if i want to put it on, i have to press on gas pedal while trying to put on and try to keep RPM a bit high like 3.000 rpm, so it would heat up a bit then it will stay on.
this is a very bad thing, i feeel like i want get rid of the car, though it's a good one except for this irrtating problem.
there are so many things to think about like ICV, O2 sensor, lambda sensor, heat sensor, Throttle Valve is new, i don't know, i don't know,
Does anyone have the right experience to answer this hesetating problem of mine, plesae advise, roger that & thanks in advance
