Guys the driver's side windor and rear windor nobs lights is not coming on any longer. Also the gear light that lits up at night doesn't come on anymore. You know the light that shows the P, R, N, D, 1 and so on. how do you fix that?
for the longest time, i didnt know that the shifter letters light up, they would be on one day, then off.... for a long time, like years ago. then recently, they are on always. talk about a weird open wire
i´m not sure if you can replace the bulbs as far as the window knobs are concerned. maybe they are a unit that needs to be replaced. you´ll see when you get them out and check for the bulb.
You can actually open the window switch and you will see a very small bulb. You can ask if they sell that bulb separetly or try to find from a car which has been in the accident. The Shifter console you have to change the bulb for shure because it is supposed to light up. Be shure to check the bulb socket properly.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
