Hello, how do I go about removing the front corner lights. It looks like I should be able to just pop them out, but I don't want to assume anything. Thank You so much for your help. Also, what is the best stuff to clean a convertible top with?
First, I use Blue Coral convert top cleaner, works real well with cotton towels. Second, for the lights, they just kinda clip out, some are in their tight, could take some paitence, just gotta get the tab off and pull them forward. Hope this helps. Also....some AWSOME stuff to clean the convert plastic window.....Mequires 10 and 16 plastic window cleaner and polish. Will make it good as new, will cost you about 15 bucks from a local auto parts store. It is easy to use. Blue and White bottle. Get them both. Hope this helps.
You should here 2 clicks when you reinsert the front corners. ..Usually, the second click is pretty hard to get. If you're not sure if you heard to clicks look down at the prongs. the clip should be passed the second wedge.. usually people push in firmly.. here that one click.. give a little test tug/shake.. and drive off... but that's really all that the first wedge is strong enough to withstand.. a small shake/tug.. as soon as you drive at high speeds that thing is gonna pop out..
This may sound like a stupid tip, even trivial.. but a lot of people lose their euro corners because of it... and a lot of people resorted to "zipties" because they think the euro clears are prone to pop out because it's happened to them.. and usually people say the same thing.. "did you hear the second click?"
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
