Hello,
I have a problem with my driver side window on 1995 318is and I can't figure out what is causing it. When the window was working properly it would drop down about 0.5 cm when I would open the door and than it would go back up to its original position once the door was closed. Now the window does not drop down when the door is opened, I thought it might be a striker plate (the plate with the small switch - picture attached) but I have replaced it and the problem is still there. I was thinking maybe this could be a problem with window motor but I am not sure since the window can be opened/closed without a problem.
Thank you for any advice
Mario
Mario
